LB7: Excessive Knock
Lance LB7
Nov 5, 2013
Kentucky
I've owned my truck for 2 and a half years now and it has always been louder than it should be. strictly speaking of motor noise. noise is not more prevalent at idle or any RPM. sounds like an early 7.3 in cab. truck was stock tuned for 1.5 years before EFI and nothing changed. injectors have 32k on them and are apparently 50% over. my guess is maybe a shotty set of injectors? thanks in advance for any help.
03 LB7
Single Cab
ZF6
500 Hp Single disc
EFI Live
Airdog 150
BD Power High Flow manifolds, 50% over injectors, banks big head, head steads
j.stanton2009
So Long Space Cowboy...
Aug 18, 2010
97
Climax Tx
03 LB7
Single Cab
ZF6
500 Hp Single disc
EFI Live
Airdog 150
What brand injectors?
j.stanton2009
Aug 18, 2010
97
Climax Tx
nope. it actually hardly smokes at all. My biggest tune is about a 200 hp tune and even it only grey hazes. no smoke at idle or anywhere else.
I honestly couldn't give you the correct diagnoses. It sounded like a stuck injector at first.
If the truck driveable; I couldn't imagine it being a broken crank or a spun bearing,
Lance LB7
Nov 5, 2013
Kentucky
Yeah I definitely don't think its any internal hard parts creating the knock. My guess is it has to be something in the injection system. It doesn't sound as violent as a hung open injector, but maybe a much more mild version of that. But yes I've run power service, lucas, 2 stroke oil. any other ideas?
Lance LB7
Nov 5, 2013
Kentucky
Problem Solved
Pulled the rubber boot around the shifter and there was no insulation around the hole in the floor or shifter linkage. insulated it up with dynamat and put the boot back on. Unbelievable how much noise came through there.
