Excessive Black Smoke.
DuramaxTireSmoker
Jun 8, 2010
339
SW Florida
I shut off the Injectors one at a time and when I shot off injector 3, the smoke was drastically reduced..:(:mad::D:spit::eek:
Funny thing is, Injector 4 was the only one showing balance rates out of spec.
DuramaxTireSmoker
Jun 8, 2010
339
SW Florida
Replaced #3. Still smokes like a pig and idles rough. I'm gonna run over things again with my V2. Could the rough idle be the FRP? according to the logs the rail pressure is fine!?
6,092
if rail pressure looks smooth on the log and isnt above 5k it should be good
DuramaxTireSmoker
Jun 8, 2010
339
SW Florida
Ok, it smoked bad. I turn off injector 3; Smoke is drastically reduced. Replaced injector 3; Still smokes. Turn off injector 3, smoke is reduced even with new injector. ..FICM??
xcablb7
Feb 8, 2009
536
Fall River
Could be low compression in cylinder 3, not burning the fue, are you sure you replaced #3 ? Not being a smart ass but my buddy replaced #3 4 times because he thought it was number 4. Number three is passenger side second one back
bittles313
Aug 8, 2010
76
Rome NY
Not trying to insult anyones intelligence here but are you sure you are turning off #3?There was a thread on here about the DVTs for shutting off the injectors possibly not being in numerical order and maybe follwing the firing order.Dont recall if a solution or answer was ever brought up as to the correct order in the DVTs...
DuramaxTireSmoker
Jun 8, 2010
339
SW Florida
Thanks I'll try the unplugging trick..
It was the seconed one back on the passenger side. I almost started replacing #5 lol.
