Info: ET Calculator added
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
ET's can be affected by shifting and 60' times. With all calculators, they aim at the "best" you could do with x weight and x horsepower. The closest "best" slip I have in that area is Kat running 11.00@122 and it lines up on both sides.
2500HeavyDuty
Book 'em, Danno!
Feb 14, 2008
2,209
Katy, Tx
www.myspace.com
ima replace my cp3 and head back to the dyno for some numbers and then the track.
alot of people say that dyno reads low, but the owner claims its as accurate as can be. best i pulled on it was 382/880 with only holding 21kpsi and 2650pw.
that wasn't a tow tune, it was all my truck could pull out:baby:
TxChristoper pulled 440/1069 with his stock trans lly. We even tested my truck with a G-tech pro RR after the dyno and it was just about spot on. it was only a 10th off my 1/4 and dead on with the mph(95). the G-tech read 374hp and like 2000+ftlbs :rofl:
but after i replace my cp3 ill get the new numbers and try out the calculator again
jacobdewey
This won't last long...
Jan 14, 2011
972
I know all the posts in this are old, but I'm wondering about the accuracy of this. I ran a 13.14 @ 103.01 mph at 6900lbs 1.867 60', then dynoed 541.2hp the next day. I know there is a correction factor on dyno's, but how would I add this in? All the dyno sheets I have are corrected, and each is using a different correction factor. The only uncorrected #'s I have are on a Dyno running no load, and I only hit 20 psi of boost, brake boosting. The numbers were 544hp. I also weighed the pickup today, at race weight. 6350lbs with me inside.
coker6303
Keep Calm and Chive On!!
Aug 6, 2009
2,484
40
Houston, TX
The calculator is a guess, doesn't mean your overall setup will cut that time. Also, corrected dyno numbers are misleading on the track...you can't correct a 1/4 pass if conditions were unfavorable
jacobdewey
Jan 14, 2011
972
I'm just trying to figure out what my real world hp would be, so I can have a guess of what class to run. I ran the estimated time last year, but I think I could do quick diesel this year. Just trying to get a guess. I've done enough suspension work, that if I'm not cutting 1.6 60's, I'm going to cry. If I run what the calculator is telling me, guessing my numbers around 580-600hp, I'll be running right at or below the 12.0 index. Do you guys think that is a just a pipe dream or is it doable?
