Info: ET Calculator added
Poltergeist
Ghost in the Machine
Aug 1, 2006
29,563
Ontario, Calif.
www.poltergeist.us
If you look at the top Navbar you will see a new selection called "Duramax Math" that is the new DuramaxDiesels.com ET Calculator. We will be adding more but this is the first. Pat wrote the formula for it using diesel truck math adjusting for it your truck weight etc.
One thing you have to be logged into the site to see the link.
ripmf666
15,123
14
47
Wentzville Mo
very close to what the old motor ran.
Your estimated ET is: 12.56
Your estimated MPH is: 106.88
What is your raceweight?7140
What is your rear wheel horsepower?568
12.54 @ 108
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
12.54 @ 108
Your extra mile per hour is your good air :p
1,866
inputted my est weight (6500) and est power (535) and it hit 12.41. IMO, Nick's tune is putting out more than the old Hot+2.
Figured 6600lbs and 545 and also got 12.40 on the nose. Its not gonna be easy to get those last .4, though.
Johnta1
Aug 28, 2008
Central Illinois
Plan on doing a 1/8th mile calculator?
My ET comes out to about 15.56 in 1/4
I don't think my truck will do that in the 1/4.
I have run many 10.45/10.50's in the 1/8th.
Using my 1/8th to 1/4 Calc, my 1/4 ET from the calculator here, and converting to 1/8th mile ET is way off.
Using the same inputs used here in my 1/4 ET Calc, the ET after conversion, is closer to what I ran.
Using my 1/8th mile ET Calc, my time is about spot on.
I think the calculator here is a little optimistic.
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
15.5 is about what an LMM/LBZ CC 4x4 runs bone stock.
What's your 60' times?
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Your calculator seems to be based on engine stand HP. None of us has engine stand data, we typically dyno the trucks on chassis dynos.
But it certainly works well for stock trucks going by the badge HP.
MMLMM
Tunergeek
Mar 2, 2008
4,086
Reno, NV
www.dyncal.com
Sweet Thanks!
Here is something that could be added.
(see pics)
