Erratic oil pressure
DIESELMAFIAPER.LB7
<----new hotness
Jan 17, 2010
5,163
12
idaho
When was this? From what I understand, they swapped to the left hand threaded shaft because of issues like that. I have zero issues with my left hand melling pump. I see normal oil pressure as well.
Mines never had a issues does run high pressure in winter 110psi when it's cold but also a fresh engine and hasnt caused me any issues. once everything stars breaking in and wearing I'm sure that'll change once warm it's like it was before
x MadMAX DIESEL
<<<< No Horsepower
Dec 30, 2008
7,535
Lexington, Ky
Ben check the engine harness plugs top of the driver's side valve cover. I was chasing the same problem simply pushing the plugs together with a large pair of channel locks cured the problem. Note: the plugs appeared to be fine before I used the pliers on them it was a last ditch effort but it worked...
Will do thanks
