Hey guys. Something fishy is going on with my cooling system. All of a sudden I'm not getting any heat thru my vents unless I'm driving and under load. Normally I would be worried about the truck overheating while I'm sitting in traffic if the hot coolant isn't flowing all the way thru the system properly, but when Im idling the heat stops blowing in the cab and the temp gauge starts going down. Then when I can give it a decent amount of throttle the heat will come back and the gauge goes up to 186ish.
I thought I had a sticky thermostat so I swap them both out and the same problem remains... the low coolant alarm is on the dash but it's not actually low. I used the bleeder multiple times now after driving and letting it cool down. Its right on the mark.
Also, as soon as I shut the engine down I hear some gurgling somewhere for a few seconds. I assume that is air in the system but I've bled it properly.... what am I missing?
What are your thoughts?
Thanks
Thanks
