Check the plug on the crank sensor. Use a meter pos on lite green, neg on yellow/blk. With the key on do you get 12v? Follow that harness back 6" it grounds to the block. It will not crank if that ground is bad.
You have the body to eng ground at the driver side rear of the cylinder head hooked up?
