A quick update first.
I decided to go with essentially a factory rebuild w/ de-lipped LB7 pistons. After reading through the threads here I decided I couldn't realistically (financially) get to my HP goals AND still be able to to tow 20k pounds reliably. Felt like I'd be chasing my tail down a financial rabbit hole that would have lead to divorce
Here is what the machine shop is doing:
Mahle Pistons and Rings
Engine Kit (Includes: Clevite Rod & Main Bearings,
Dart Cam bearings, Melling Oil Pump,Gaskets)
Arp Rod Bolts
Arp Head Studs
Sbi Guides
Jet Clean Parts
Install Bronze Guides
Delip Pistons
Bore & Hone Block
Resize Rods/Ck-Hone Rods
Assemble Rods & Pistons
Valve Job
Balancing
Key Crank & Cam
Magnaflux / Crank
Mill Heads
Deck Block
Install Cam Bearings
File Fit Rings
Check/Adjust Line Hone
Assemble Long Block
In addition to the engine stuff I'm doing a turbo back exhaust, adding an external oil cooler, a CTS2 to monitor everything, a PCV reroute and an EGR Blocker plate (I still might need emissions so I didn't want to delete it altogether)
My questions are:
-Is there any seals/hoses in around the engine that are easier to address while the engine is out? I'm going to replace some of the rubber fuel hose on the injection side of things. Can I reuse the return fuel lines?
-I'm going to use a parts washer to clean up as much as I can like the Y bridge, exhaust manifolds, oil cooler, etc. Can I clean the turbo the same way or is there seals, etc that washer fluid could ruin?
-Anything else I'm not thinking of?
What is a good break-in procedure to do before I tow anything?
Thanks again for all the help!
Casey
Arp Rod Bolts
Arp Head Studs
Sbi Guides
Jet Clean Parts
Delip Pistons
Bore & Hone Block
Valve Job
Balancing
Key Crank & Cam
Magnaflux / Crank
Mill Heads
Deck Block
File Fit Rings
Assemble Long Block
My questions are:
Casey
