Id like to start a thread that logs details of our Engine specs, then that engines Failures so that we can compare and then analise some of the results to see what consistancies and inconsistancies come up and then maybe get some more definitive answers. I'll start of with what I think and as we go no doubt others will add what they think is important. I only have one failure so far, but looks like I'm about to have another one go thats starting to clatter really bad, maybe the result of a bad injector on this new engine.
ENGINE SPECS
TYPE - 04 LLY
ENGINE BUILDER - GM
TUNING - EFI
MAX HP - 881 repeated
MAX TQ - ?
STREET DRIVEN - YES
DRAG -OCCASIONALLY - STRIP
PULLER - NO
TURBO(S) - PROCHARGER SUPERCHARGER INTO GT45
AIR FILTER - K&N
INTAKE MANIFOLD - BANKS BIG HOSS
EXHAUST MANIFOLDS - SS HEADERS
DOWNPIPE - 4"
MAX TIMING - 31deg 3800 RPM
AVERAGE EGT'S - 6-700
MAX EGT'S - 1350
FUEL PUMP(S) - 1 X STOCK PLUS 1 X PPE
INJECTORS - STOCK
HEADS - STOCK
RODS - STOCK
PISTONS - STOCK
CRANKSHAFT- STOCK
BALANCER - STOCKOIL PUMP - STOCK
TRANSMISSION - SUNCOAST STAGE V
CONVERTER - SUNCOAST 1059
CONDITION AT FAILURE
MILES - 35,000
BLOCK - HOLE AT NO 7
PISTONS - ALL IN GOOD SHAPE - NO BURN MARKS
RODS - ALL BENT EXCEPT NO 7 BROKE IN HALF
BORE - AS NEW
CRANK - AS NEW
TURBO - GOOD
ENGINE SPECS
TYPE - 04 LLY
ENGINE BUILDER - GM
TUNING - EFI
MAX TQ - ?
STREET DRIVEN - YES
PULLER - NO
AIR FILTER - K&N
DOWNPIPE - 4"
MAX EGT'S - 1350
INJECTORS - STOCK
HEADS - STOCK
RODS - STOCK
PISTONS - STOCK
CRANKSHAFT- STOCK
MILES - 35,000
BORE - AS NEW
CRANK - AS NEW
TURBO - GOOD
