Okay so I've been wanting to run electric fans for awhile. My stock fan is hitting my fan shroud when I get on it, I'm gonna get merchant motor mounts. But I was wondering what are some good flowing fans? I live in Texas so gets pretty warm.
Taurus fans would be the highest flowing and cheapest option that I am aware of. They work amazingly well on my truck. So well in fact that they bring ect down from 215+ degrees after a run to about 175 in 5 minutes or less, depending on ambient temp.
There are a few good diy threads on here and dieselplace. there is no "kit" for what Tim has...
What temperatures do you see in your area? I still daily drive the truck and see 90 degre wether here. You have a link to the fans?
Junkyard, Last I looked they were like $6 each. I have them on my pulling truck
Yukon Denali or caddy escalade fans from a junkyard work pretty good, too
That seems like the best option to me. Do they bolt in like they're factory installed?
I found this on NAPA's website:
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=NDP8552347_0407779467
Compare the size of that fan assembly with the Dmax rad size:
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=NRS2986_0237460145
They are pretty close.
Ive got two Taurus fans sitting in the garage waiting to go on the little truck. Just have to fab up a frame to mount them to and get a controller and temp sensor.
Controllers: http://www.dccontrol.com/relay_controllers.htm
Metripak connectors: http://www.metripack.com/
Wiring design: http://www.davebarton.com/pdf/coolingfandiagrams.pdf
More wiring: http://www.rx7club.com/2nd-generation-specific-1986-1992-17/wiring-taurus-2-speed-fan-839089/
Yet more wiring: http://www.jeepforum.com/forum/f12/ford-taurus-wiring-solution-cheap-1325896/
Another option: http://www.pirate4x4.com/forum/gene...taurus-fan-taurus-fan-better-application.htmlhttp://www.jeepforum.com/forum/f12/ford-taurus-wiring-solution-cheap-1325896/
I only have to use them when it is 80+ degrees ambient. Cooler than that and my truck runs too cold normally. She's a cold-hearted b*tch! I find them on car-part.com. Ebay is usually a rip-off. I had a friend that bent up a piece of 18g SS for my top bracket and I used a few strips of aluminum flat stock across the bottom to space them properly. I found out the hard way how to clearance them away from the radiator!
I use a Dakota Digital two fan/two speed controller that taps into the existing ECT signal wire. Both fans are on 50A relays.
