:roflmao:You need to step out of this one. It's over your head.
Most things are Mike, most things are...:hug:
Well, I'm not sayin his idea is gonna work, is good, bad or otherwise...
Ok mike
I respect you as a professional, your input and what you've accomplished, what you stand for...etc, and I'd probably believe just about anything you said regarding anything transmissions:thumb:
So, Just for the grins and giggles...
Correct me then, please...
wouldn't you agree that if he tested his idea in a fish-tank using water as the test medium, his results wouldn't be nearly as accurate as they would be using trans fluid or similar, since that's the fluid the system he's implementing will be moving, it only makes sense that a "data test" should use the same type of, if not the exact same fluid, as the fluid that will be used for the end product? Right?
That's all if was trying to say, I'll step out now
