I ran DT max effort stock turbo,injectors tune for a while, would bury my 1600* gauge. Switched to Rob and it wouldn't go past 1500* not matter what and made 515 on dunbars dyno.
You have a correlation between your ET and MPH... You could squeeze more ET by going faster in the 60'. You could get probably 12,3-12,4 with a 1,7X 60ft and maybe 12,25-12,29 with something in the 1,6X range.
But still, if you are on a max effort tune, your mph is kinda on the low side... You should atleast get 110-111 mph easily out of your setup.
All depends on your race weight too...
What kind of rail pressure do you have?
stock injectors? I was running those same times on stock turbo on my LBZ, but saw 1600*
I was hitting 1375-1450 depending on the day, 30% inj. Sounds like you need to fine tune the MAF down low.
My race weight was 7,100. I did not do any sort of weight cutting or anything.
My commanded rail pressure is a little over 27,000. I am seeing 22,000 to 22,500.
