EGT on track
ouellet5
92
I'm running stock engine , What's the highest point i should'nt reach ?
Last time on 1/8 miles i got a maximum of 1400, it is good ?
thanks
coker6365
Coker6303's ***** Daddy
Dec 4, 2011
486
If you are watching EGT's going down the track, you need to go faster. Lol
Short runs will not hurt anything. We see over 2000 degrees regularly.
Sent from my SM-G965U1 using Tapatalk
1,795
I used to see 1700+ sometimes, but only at the top of the run, a couple seconds worth.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,428
437
Central OH
That's why you buy one that only goes to 1600F, no point in knowing if it goes past that. I've had mine burried more than a few times
2,046
So when are we going to get Zirconium oxide turbines that can withstand several thousand degrees? And our turbine housing will melt before the turbine fails
2,046
I've seen a few burned exhaust valves and I think I saw a photo somewhere of some turbines with some melting/erosion from excessive heat. No first hand evidence of that last part though
coker6365
Dec 4, 2011
486
Does melted rubber in fender wells count?
hntngkd
162
5
Attica, Mi
I had a turbine wheel start to melt on me. Didnt even notice until i got the turbo back from FI and he sent back the old turbine wheel with it.
Sent from my SM-N960U using Tapatalk
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I have a 1600* gauge with the warning light set at 1600. Once the light comes on I count to ten or get scared and let off.
