I have a 04 Lb7 EGR in my truck I also have a non EGR engine can i install the non egr in my truck and just reprogram the peramiters with efi live to keep the light off etc.Can anyone walk me through this please thanks
I have a new motor with out egr and want to put it in my EGR equiped truck I just want to know if i can put it in with out swapping exhaust and intake etc.I know i can shut off the egr etc with efi I just dont want to put the motor in and then find out i have to change the y-bridge and intake i am lazy and its alot of work so what should i do
I have the motors out and on stands I just want to get the new 1 in i miss my truck since April 4th and have not much time to work on it but i have to get it done thanks for any help
You should be good, the y bridge ends at the same place where the cooler tube connects. Exhaust will line up too, I think the downpipes off the turbos are different though?
I thought it was just the up-pipe on the pass side? Either way he is all good if not better
I know the up pipe is different for the EGR/Non EGR, but I thought the downpipe was different? I might be wrong though.
dave, you can swap the pass. side up-pipes and intake from the other motor and completely remove the egr without swapping motors. and then re-program the ecm with efi live to get rid of the egr codes.
