EGR Delete LBZ LMM
dmaxed 67
Jan 3, 2009
54
ok Im egr ignorant whats the benfit whats the draw back,does it hurt your waranty,and ill you throw codes,I think gm just out a new egr in my truck for free
Jun 28, 2007
3,259
NE Pa
Is removing the egr pretty straight forward? Also is this kit complete or do I need some gaskets or anything else? I have the egr blocked so there's probably no reason to keep it on there right?
What about the throttle body on an LMM ?
You will need a federal riser pipe for the back of the engine.
It goes away with this.
Correct, there are a fw other ways around putting on a fed pipe though
13,715
779
Where does everyone get this fed up pipe?
You can buy them new for somewhere around $120. Maybe a little less, maybe a little more depending on your dealer. You might check with Henry to see what kind of price he can give you.
JD4440
<< Lo-Carb Monster
Feb 27, 2009
1,776
Orlinda, TN
Getting close to this piece on my list. Never seen where Dave's question was answered though. Does having the EGR motor removed throw a code ? What's the P/N for the LB7 up-pipe? If I don't swap out the pipe is there a thicker plate to mount where my blocker is now ? Thanks guys !
JD Dave
In way over my head
May 19, 2008
2,388
Caledon, Ontario
It throws a couple codes but EFI took care of them. No idea about the p/n.
ripmf666
15,123
14
47
Wentzville Mo
Guys Paul has been working so not sure what is going on with the EGR Delete Kits. If I dont here anything i'm going to close this down and take them off the site til we figure something out sorry.
