efilive tune for vane control
teamster
Mar 24, 2011
can any one help out with info on tuning with efi live to fix a turbo vane issue? keep in mind im extremely novice. thanks. a little history; i have an 07 lmm cc dually. about a year ago gm put in a new vane switch. didn,t fix it. then they warrantied a new turbo. couple months ago, another vane code/issue. they say it needs another switch ( only this time i pay ) can efilive help? have a duramileage ecm, dpf delete, and hasn't helped with the vane issue. any similar experiences?
BHoward6.6
West Coast
Feb 9, 2011
274
Huntington Beach, CA
The main engine harness on the top of the motor, take the two apart and inspect the pins for corrosion. Clean the pins, apply a little dielectric grease, reassemble.
I had the same issue and this is what it was.
