I have a 2008 with EFI and DPF delete, truck now has 242,000 miles 4x4. It still has egr and a cat.
I run it on the 65hp tow tune and have for 4,000 miles it still runs like it did with the DPF on power wise. The egts are cooler and boost is higher, egts stay under 1400 99% of the time and will 25-30psi. Fuel rail presure is within .2 of what it's demand is. When it wants 26k it's getting 25.8-26.1. I have had the tunes redone.
Fuel filter was replaced, new air filter, trann temp is normal. I have a lift pump just need to get home to put it on.
0-60 edge times were .02 faster from stock to 65 tow.
What do I need to check?
