I start at post #22 here: http://forum.efilive.com/showthread.php?22546-Need-help-ASAP-0101-no-data-recieved-error/page3
Cant get this LLY to even read.
Maybe log the truck and see if the data shows stock numbers. Maybe corrupt files? No problems reading /flashing any other trucks? I know that should be able to read either way. I'm just throwing ideas out there.
I had a problem reading/flashing an LLY once, and it was because of an aftermarket alarm system that I didn't know was installed on the truck. Just one more reason why LLYs suck... oke:
Steve i called you about a similiar issue or maybe the same cant remember a couple of weeks ago when you sent me that LLY tune. What i had to do to is switch it to a lbz ecm instead of the lly. Flashed first time. Sure youve already tried this though but figured i would throw it out there:thumb:
I have had this same issue several times.... Can you try bench flashing it? I bought a harness and bench setup for. Problem Lly I had and after bench flashing it.... No problem.
I ended up just popping the knee bolster and disconnecting all the power wires that were tied into the ignition switch and reconnecting the one that the alarm was spliced into. I didn't totally remove it from the truck. Took maybe 5 minutes.Son of a bish... I asked him about it and it does have a compustart alarm/remote start. Hard to take that out...
