Efi help for arson 2 cp3 kit for lbz
Mikey
Drag Racer
Jun 13, 2009
560
Anybody familiar with what changes in efi live i need to make for an arson ii kit?
Mikey
Drag Racer
Jun 13, 2009
560
Anybody know exactly how to change this. I am new to EFI Tuning.
I can see the Desired flow vs current graph. What's next? What do I change?
Bryce418
Still slow
Oct 5, 2009
611
It's not terribly hard per say, you need to add current at lower fuel pressures mostly around the 4-8k psi area.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Start by going to B1015 , add 75 ma in the 0 and 2230 cells (if its LBZ ) , blend to the next 2-3 cells past those 2 with out changing the min / max and test , add more or subtract depending on results and repeat as nec .
TDFDiesel
I'm That Guy
Jan 6, 2011
386
Mesa, AZ
The OP asked for help as he's new at EFI Live... being an asshole wasn't in his question.
Wow.. Big talker on here.
I was asking for his definition of hard. Does he mean this is a quick change and no data logging / testing, does he mean he's ok with tweaking with it for awhile, what does he define as hard?
Some guys find changing the tire size is hard, others don't care about messing with boost, timing, frp, pw tables, etc...
jon5212
Oct 13, 2010
119
Then on the first post maybe you should add a little more information, or if you wanted to help a post saying send it to a tuner doesn't help either.
Mikey
Drag Racer
Jun 13, 2009
560
How would you describe surging?
Truck Drives very responsive. I also added a batmowheel.
see pics
