Edge CTS Mounting
Chapman_4
Jan 18, 2012
29
I was wondering if anybody had they edge insight mounted here or if you had any other unique spots for them. I have a pillar mount with mechinacal gauges already in it so my old dash pod won't work. Thanks in advance for any opinions or options.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I have mine right there. Just cut a small hole in the back of the cubby to feed the wire through and run it under the dash to the obd2. Edge insight cs fits perfect. its just pressed in.
Chapman_4
Jan 18, 2012
29
How big a hole did u have to cut? Seems like it would have to be a pretty good size.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I put mine down low because I hate having all that light up on the pillar. Creates a distraction at night.
And as far as the holegoes, it isn't huge but it needed to be big enough to pull the connection to the back of the cs through. If I remember correctly it is the entire height and maybe a little less than 2 inches cut in from the corner
Edit: I made 3 cuts so I didnt have a piece to put back in. But if you did it right you could cut a big hole. Pull the wire through then tuck and glue the piece back in and notch a small slot for the wire.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
With the boost and egt on the pillar I don't look down at mine much. More used to switch tunes.
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I just noticed you said CTS. Mine is a CS. your won't fit where mine is without having it hang out.
Chapman_4
Jan 18, 2012
29
Yeah I seen that but I thought about using the top hole since there is a little lip there and using some velcro on the bottom of it
