LLY: Easiest way to remove broken bolt?
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
I can get it to move side to side a very little bit and back and forth a little. Trying to pry on the top behind the line against the fitting and top of valve cover. Little bits at a time.. Here's a pic of the platform that got busted in this horrible process..
do I need to replace the lower valve cover or can I do something to get by...
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
Damn, i got nothing. Other than possibly freezing it and smackin it with a small punch, hope it shatters and then blow/vac it out
Burn Down
Sep 14, 2008
7,092
Boise Idaho
If the button will stay in place when you get the new injector in and torqued in place it should be fine. But I would be on the hunt for a new lower valve cover. What does GM want for a new one?
Did you try the slide hammer trick? It works great on Cat engines. If I hadn't gotten mine out finally, I was going to build a adapter and bring my slide hammer home from work.
Slammed2007Lbz
Super Spicy Tunaz
Feb 1, 2009
1,118
NE Ohio
My old Dmax i had to heat the head up cherry red to get a injector hold down bolt out. The head wasn't broke off like you have i had to heat it up that hot just to break it loose!!! It creaked the whole way out and once i got it out the bolt was in a s bend snap lol! Luckily it didn't break i was amazed, i told myself if this bolt didn't break there is no way in hell anyone will ever have one break. I figured they were hardened. Good Luck
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
I may have to do the slide hammer trick. I've been through hell and back with this dam injector. Now have to drill that snapped bolt out. I have a set of lower valve covers coming. Hopefully that's not a horrible job
3,733
305
This is making me feel better about owning a LB7. I may have to replace the injectors more often, but at least there is easy access to put a crows foot pry bar under them. Pulled them all that way, was so much easier than the "proper" puller.
Sent from my Galaxy Nexus using Tapatalk 2
Devon
broke my curse
May 2, 2010
807
Hinsdale ma
Well I just dropped the dmax off to the dealer. Just going to bend over and wait for them to do me dirty. Whatever I don't have the time to pull the valve covers and r&r them. Oh and that shit ass injector.. Looking atleast a grand I bet...fail!
Slammed2007Lbz
Super Spicy Tunaz
Feb 1, 2009
1,118
NE Ohio
:confused: How do you heat up aluminum cherry red?
Sorry Josh i meant the bolt:spit: The head wasn't red at all except just the flames on it but the bolt was bright red lol. Sorry i made it sound like the head was glowing red but I'm sure you got the point
