Bet it looks like this when you get it out...
You could build a slide hammer with a old injector line cap, just weld a nut that fits your slide hammer to the old fuel line cap. I put the fuel line back on and had to pry between the valve cover and the cap to get the injector to twist back & forth, while keeping up tension on the injector with the other prybar between the valve cover and the hold down. Lots of penetrating fluid and cussin, 4 hours later it came out... It's would be easier with an extra hand.
If you look close at the copper washer you will see a dark circle in the sealling face. That is a piece of carbon that had fallen into the bottom of the injector bore when the dealer changed that injector. The Tech didn't see it or was in to big a hurry to care. That allowed combustion gases up around the injector body and froze it in place. That injector had only been in for less than 3,000 miles.
