Dyno of "Casper"
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Casper is a 2005 2500HD GMC LLY Duramax/Allison with 9,000mi
The engine is untouched (OEM head studs, internally stock, stock injectors, and CP3)
We have the standard "minor mods", such as exhaust, intake, EGR delete, etc.
We put on 3 major power adders: High Tech "McRat" Charger, PPE Dual CP3 System (LLY secondary CP3), and McRat EFILive Tuning.
Dyno was done at Westech in Mira Loma California at a SuperFlo Chassis dyno. STP correction was used. Dyno was a ~6 second sweep from 80mph to 115mph to emulate dragstrip conditions.
We made 659rwhp peak and 1315TQ. Actual torque is higher, but for drag racing we do not care what occurs under 2500rpm, as the engine does not operate in that area for more than .2 seconds.
I cannot "scan" this into an image right now, as my scanner just makes PDF's. You must have Adobe Reader loaded to view it. Performance past 3300rpm and below 2500rpm will be tested shortly running our sled pulling tuning.
http://dieseldrags.com/diesel/2CP3v3-Casper.PDF
Was this dyno'd like everyone does? No. I dyno for my own information and tuning purposes. But there is little doubt there is a bunch of HP. We do not claim to be making more or less power than other combos.
Kat
Wicked Witch of the West
Aug 2, 2006
17,899
13
60
Norco, CA
New numbers today with a different version of the same charger:
674.6rwhp, 1378ftlb. But alot more area under the curve. 650+HP at 3400.
Kat
Aug 2, 2006
17,899
13
60
Norco, CA
I just don't want any friendly ghosts catching me :eek:
Poltergeist
Ghost in the Machine
Aug 1, 2006
29,563
Ontario, Calif.
www.poltergeist.us
Kat
Aug 2, 2006
17,899
13
60
Norco, CA
Some L92 info but there are the usual 'stupid' posts you have to weed through.
http://www.ls1tech.com/forums/showthread.php?t=499059
L92 intake, the intake ports on the heads are not the cathedral design so a new intake is needed.
http://www.ls1tech.com/forums/showthread.php?t=552392&highlight=l92
Basically:
block: $1300 (6.2L)
heads ea: $400 (assembled)
intake: $500 - (last heard) with fuel rail, injectors, throttle body
Parts and just now becoming availible to be ordered.
Thanks Rob,
I will have Pat read through it :angel:
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Here this might make you think twice about Gassers :)
http://www.youtube.com/watch?v=u8NwWBIzllc :eek:
this is befor the Twin hair dryers.
search this truck out his street racing vids will crack you up
Yeah Parish is certainly fast. But his claim to be the fastest 99+ truck in that video might not be accurate. Buck and Jesse went 10.4's in their Dmax last year.
OPPSS!!! That's a pretty old video.
