Dyno 12-21-15
Bustedknuckles
Honey Badger
Sep 25, 2010
1,308
33
Hagerstown MD
512.5/948.6. Said they couldn't load it enough to spool the turbo?
Thats 7 hp less than the best mine has ever dynoed! Same mods except i have a s366 and stock manifolds. Idk why these guys thought you would make anywhere near 600 hp.
Edit: i was only 2 ft lbs off on the torque...
lil bleur
Its all good until..BOOM!
Oct 6, 2015
151
York PA
Who's tuning u running? cz A customers LLY w/ a GT37 (stock everything else ex for lift pump and trans) dynowed 538/1100 on Antrim's Dyno...Danville tuned...never mind I see its in your signature.
NRA223
May 20, 2015
288
I don't know what gear they ran it in. I thought it should make 600 because that's what every other truck with this turbo that I've heard of has made.
NRA223
May 20, 2015
288
U data log it?? Your CP3 must be weak. Quite a few stock trucks make that Lol. Maybe they weren't running it in O/D??
No I didn't log it. I kind of doubt the CP3 could be weak with the low miles. This was only the 2nd diesel they had dynoed. They said they were telling the dyno the truck weighed 15k lbs to try to load it. If it wasn't in od what would the effect be?
Bustedknuckles
Honey Badger
Sep 25, 2010
1,308
33
Hagerstown MD
Antrims dyno has always disappointed me, according to it i lost 2 hp from another dyno going from stock injectors to 30% over when it is much stronger feeling. I think it does good on vgt trucks that spool super quick though.
jacobdewey
This won't last long...
Jan 14, 2011
972
My uncorrected numbers were 580/1100 on my compound/stock setup. Corrected it was 730/1300. That right there tells you how much the dyno operator and setup comes into play. I doubt anything is wrong with his truck.
NC-smokinlmm
<<<Future tuna killer
May 29, 2011
5,220
369
At Da Beach
Go run it at the track. That will tell you what it's really making. According to a mustang dyno I lost 90 hp with a 68 on my LMM. The track told a different story...;)
NRA223
May 20, 2015
288
Yeah the truck runs great so I guess I shouldn't worry about the dyno numbers much. I do have an up pipe gasket that is bad now though. I'm picking up a sportsman pump on the 2nd too so if that was an issue it won't be anymore.
jacobdewey
Jan 14, 2011
972
My truck dynoed closento 900 hp on custom autos dyno.....
Yeah, Custom's dyno isn't a heartbreaker, more like a head inflater.:rofl: I dyno'd 665hp with a bolt on BD turbo, conservative tuning, and a worn out cp3. My 13.1 timeslip told the truth.
I started asking for uncorrected numbers because they were always way closer to what my timeslips told me.
lil bleur
Oct 6, 2015
151
York PA
I've never understood, What's the point of Corrected numbers?? To set u up for disappointment at the track?? How come corrected is even an option??
