Duramax Thirdgen Camaro Swap
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Big blocks (cast iron block) weigh in about 600-700 depending on how they are dressed and options. Dmax engines are 900-1100 depending on what you call "dressed". All without the Allison
The 6.5 was essentially a modified small block. Same ballpark weight as a small block.
The allison weighs 330 dry. 4L80E about 150 dry.
A 6.5 weighs in around 675 IIRC with a turbo. It definately isn't based off a small block as I've got one sitting out in the shop, but I'll agree it isn't quite asd large as a big block. An iron block 454 vortec is said to weigh around 750 or so. I know that the DMAX/ALLISON package only adds 275 pounds over a 6.5/4L80E package as both myself and Gordon just down the road from me have both done DMAX swaps in our GMT-400 SUBURBANS, and we both saw weight gains of about 275-300 pounds for both trucks. I know the ALLISON is about 150 pounds of that weight gain as well. When I was researching my swap the weight I found for an LB7 was right around 825 pounds which supports my weight gains after the swap.
lunati397
Sep 21, 2011
33
from what ive found its 820 fully dressed and im using the 4l80e not the allison so there will be some freed up HP from the less rotational mass and weight loss
Thefermanator got any tips on the wireing harness
1,943
Well, I guess if Woods can fit a Dmax into a Fox-body Mustang then you can fit it into that Camaro. Sure is going to be an interesting car when you're done. Youve got a LOT of fab work ahead of you. Good luck.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
GM says the duramax weighs 837lbs, FWIW. Even fully dressed with AC compressor, power streering pump etc I would be VERY surprised if it was more than 900lbs.
fast03
1,201
61
Rancho Cucamonga
Cool project. Something I would like to do when I get some space in the garage. I can see the torque numbers being an issue with the chassis.
lunati397
Sep 21, 2011
33
I was thinking the same thing. that may cure his firewall clearance issues.
I want to do a compound setup and keep the stock one there for now it will clear the hood and be perfectly in line for the scoop on the ss hood so I might fab up a new intake horn and filter box and pull straight from the scoop if that works out ill look into a larger turbo if not then ill do a compound setup or something along those lines where 2 turbos are involved
lunati397
Sep 21, 2011
33
right now im just trying to get my hands on some DOM tubing to build the front K member Ill be pulling out the stocker soon and building a Jig from it to build my own
lunati397
Sep 21, 2011
33
got the front cross member off start building the jig tomorrow but I have to put new brakes on the wifes car and a wheel bearing on a friend bmw but after that I should have time
lunati397
Sep 21, 2011
33
didnt do much today it was windy as hell and cold out but decided to strip some of the paint in the engine bay have to wait till monday to get some steel for the jig and some sheet metal to start patching and smoothing firewall
lunati397
Sep 21, 2011
33
brake booster is coming off the truck and im going to swap it on with the camaro one they hydro boost is alot smaller an in my opinion i like the looks more too that will free up alot of room
got some parts to order and K member to make then ill be stuffing it back in again
3,729
297
Plus, the hydroboost works better than the vacuum boost IMO. That, and you don't have to worry about keeping the vacuum pump (unless you need it for A/C controls in the cab).
lunati397
Sep 21, 2011
33
got some stuff done today cleaned the garage and worked on the jig for the Kmember still waiting on DOM tubing
half way through my bandsaw broke so I had to use the cut off wheel for the few remaining cuts I hate them because I have had discs come apart on me
but all in all got some good welds for a temp fixture lol
:mad:
