Hello, I want to put a duramax in my mid 70s 3/4 ton 4WD and I want to run it with a manual trans. I have located what looks like a good donor truck, its an 06 with LLY/ZF6. My question is would it be best to start with a donor truck to start my build or would it be easier and cheaper to just buy a pulled motor and trans? Also I have heard that you can use a NV4500 behind a duramax as long as you don't go crazy power or tow a lot? The NV4500 would be much cheaper if I didn't go donor truck route. I would delete and tune the motor looking for maybe 450-500hp, nothing crazy and I would hardly ever tow with it and anything I did tow would be light. One reason I would lean toward a donor truck would be to use the intercooler and radiator in the swap but I have heard that you don't necessarily have to use an intercooler, is this true? It'll have 37s and 4.10 gears.
