Duramax rebuild. problem with exhaust valves
rungesco
Feb 5, 2011
Wisconsin
I am rebuilding a lb7. when i turn it over it turns over smooth intil i install the rocker arms. on every cylinder the exhaust valves hit. none of the intake valves hit. it is times so that the single dot on the cam in in the center of the two dots on the crank, at number one top dead center. any ideas or insight on this would be great thanks
S Phinney
4,008
Quncy, Fl
Are you running a aftermarket cam? Are you running stock rockers? You sure the marks are lined up? Give more info on the build please.
Sent from my SCH-I500 using Tapatalk
rungesco
Feb 5, 2011
Wisconsin
im not positive im posting this for my buddy he doesnt have a computer handy. will it be off if it is timed on one compare to the other?
02dirtymax
149
Ohio
Made that mistake once after doing head gaskets...... Suprisingly enough it runs pretty decent, just makes alot of noise, especially once you throw a pushrod.
13,701
756
Have you pulled the cam gear to make sure the alignment pin isn't broken?
