Duramax LML DEF issue and Deletes Wanted
ujtruck
May 7, 2016
Hi Every one! I'm new here
My Truck: 2013 GMC Duramax LML, around 90.000Km have check engine light, scanned DEF Heater is the culprit, now as per my GM Dealer she is out of warranty, i will have to pay for all repair cost and truck must stay at Service Bay 3 or more days - (not acceptable, its my work truck)
OK: I found a guy, who can Delete DPF and put a pipe, delete EGR, delete DEF functions from engine computer and re-program with 3 Tunes for $1300.00
It little pricey for me, however, is that a good deal?
Or should i buy EFI Live and email delete/tune the Truck my self?
what else / issues i should watch out for, when they do all that ?
I live in Ontario, Canada.
Any and All inputs: Thank you in Advance.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
Emissions equipment is covered under a government mandated warranty that far exceeds the factory warranty.
I can't remember the exact terms but I'm pretty sure it's something like 7 years and maybe 200k miles or something like that.
duramaxdiesel
Dmax Nut
Oct 23, 2008
1,378
47
Montreal, Canada
^^^^Exactly what he said. But if you're looking to delete anyway... $1300 seems pretty high. But up here I see people getting away with it. It boggles my mind. If I was in your situation, I'd buy a V2 and have tunes emailed to you via a reputable tuner here.
Nick
ujtruck
May 7, 2016
Was the 1300$ for a full exhaust and delete tunes or just the delete pipe and tunes?
1300$ for DEF delete, (DPF replacement shorter pipe) , EGR delete (install that blocking plate) then tune.
so yes Just a delete pipe and tunes
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
Full exhaust $400-$600
EGR blocker plate $20
EFI Live autoCAL with tunes $600
All figures in US dollars and ballpark from last time I noticed the prices
If you have about a hour a ratchet strap and an open end wrench you can do the egr delete yourself. A shop should only charge around $200 to install an exhaust and takes about thirty minutes sitting in the seat of your truck to install efi live. :)
Edit: ratchet strap and wrench worked on my LLY idk about them newer trucks I haven't seen the EGR setup.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
I'd like to know where you can get an LML autocal that cheap....^^^^^^
NinjaMax
WTF!
Oct 3, 2012
1,266
42
Severance, Colorado
I got a full 5" flo pro and auto cal with delete tunes for under 1300$ from a vender here. Im told that a blocker plate isn't needed on stockish lml's due to a stronger valve (someone might verify that?).
Edit: just realized your in canada, maybe shipping is a big factor?
Digmax
289
I just did a full egr delete, went 90000 miles with just delete tuning and my intake and heads were still clean so don't think full egr delete necessary on lml
ujtruck
May 7, 2016
OK DEF / DPF / EGR / CAT deleted, from Turbo all the way straight pipe, yes its little loud, but lots of turbo whooish...whooish
HWY Millage was 16/100L now 11/100L cool
City stop and Go 13.5/100L
i feel, little bit lag at stop light then go, but once going everything is good, may be i must buy EFI live V2 and tune a bit
now you pros guide to buy V2 and some good tunes please
thank you!
DefiantArms
Limp Mode Cowboy
Jan 28, 2016
897
St. Augustine, FL
thank you!
Having trouble understanding this but if you're asking where to get good efi live tunes we have site sponsors that are the tits and you can find them at the bottom of the forum page. Atp trucks, ppei, creatures of the night ect
Max Attitude
11SIX
Mar 7, 2012
814
Caledonia, MI
thank you!
You deleted without tuning it? I bet you have one pissed off truck. Eventually you will be in limp mode.
$1300 for everything installed isn't that high but it's not cheap.
ujtruck
May 7, 2016
No, we deleted everything and he put some HP tunes, everything is running OK so far.
but I want to tune with EFI live, cause I heard good thing about it and trucks runs very good
it that true?
sorry for asking stupid question?
I am new to tuning
