Ok, we finally have these ready for market to take care of the issue once and for all without adding any undue stress to the crank and belt stuff. Not sure why it took me so long to figure it out but we have it now! This uses the factory or aftermarket belt routing for dual fueler setups so that you are required to do anything crazy with it. Add this and forget about it!
On the LLY and up trucks you will want to get yourself a 14x2.0 Tap to clean the threads in the block where it mounts so you don't break it off in the block like I did in my wife's truck... I'm just saying, don't be dumb like I was...
D-Max High Performance Idler Kit (LB7 2001-2004)
Danville Performance for all of your performance needs.. Home of some of the most competitive DMax's in the country!
www.danvilleperformance.com
D-Max High Performance Idler Kit (LLY, LBZ, LMM 2004.5-2010)
D-Max High Performance Idler Kit (LML 2011-2016)
