Duramax DD/weekend warrior build
jdlover1
437 Cubic Inches
Oct 4, 2006
538
chapanoke,nc
I am in the planning/saving money stage to do a DD/weekend warrior engine build. I am shooting to be in the 700 to 800 hp range. Now i know about the must have parts and the optional parts. My question is what about the parts you dont hear alot about:lifters,push rods,oil pump, etc can i reuse them or buy new oem or aftermarket?
721
must have :
rods.
duelfuelers
turbo(s)
lb7 pistons will live at this level
good to have:
keyed crank/cam
head studs
main studs
cut/coated LB7 pistons
option:
ported heads
afrter mark cam
fordge pistns
cam vlv train is pretty solid up to 4500-5,000.. nothing wronng with over building either.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
I disagree with you Adam.
If you have the motor out of the truck you would be a moron to put it back together WITHOUT keying the cam and crank. Keying the cam and crank is a MUST.
Dual fuelers a must have??? what????? We are talking about basic stuff to allow the motor to live safely. This has nothing to do with dual fuelers.
ben
jdlover1
437 Cubic Inches
Oct 4, 2006
538
chapanoke,nc
i was asking what should i do about the lifters,push rods, oil pump. i am getting carrillo rods, cut and coating my lly pistons, socal cam,socal heads, keying crank,ati harmonic balancer,main and head studs,injectors.. i already have the duel fueler and turbo
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
If you have the motor out of the truck you would be a moron to put it back together WITHOUT keying the cam and crank. Keying the cam and crank is a MUST. I would def do this to:)
ben
Ben the OP wants 700 to 800hp, I think a second cp3 is needed:)
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
I realize that. The way he posted the question, I thought he was looking for answers on "what to do to be safe", not "what to do to make this much performance"
721
ben
that was a typo on my part :eek: it is a must have.
for 700-800hp goiing to need duelfulers
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
wow good job adam, you just ruined this thread, now its gonna get into "well why do the LLY's crack easier...under what conditions did ricks pistons crack....why arent stock LB7's breaking pistons even tho they run the same pistons as LLY's....BLAH BLAH BLAH"
ben
Dec 2, 2006
1,696
TN
ben
Grow up a little bit..
721
ben
not really... you mister opened the door i wlked through it ;)
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
How high do you plan on reving?:)There are a few weak links in the heads
How much of a budget? They get costly Fast it's not nickels and dimes.....it's 50s and 100s:eek:
