Dumbfounded
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
I just replaced all my brake lines this week and while at replaced the batteries.
Now it wont fire. Just cranks. It ran probobly best ever last sunday, sat a week and now nothing.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
try touching the ecm with a ground wire and have someone try and start it while you have it grounded,its a long shot but try it and see if it starts we just had this problem.Reluctor wheel come loose by any chance ive heard a few people here lately having that problem.
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
Might be worth checking to see if the anti theft is enabled in the tune , if so disable it and see if that does it .
3,727
296
If the lights are pulsing, just double check that the battery connections are all tight. I have found that a loose connection on one of the batteries can cause all sorts of strange problems.
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
Just scanned it. Came up with:
P0089-FPR Performance
P0090-FPR Control Circuit
U1800-Lost Communication With Fuel Injection Module
I didnt touch motor other than battery cables and it ran best ever last sunday when I took it for a ride.
Any sugestions on what to look for? or did FICM take a dump?
blk smoke lb7
Nov 8, 2010
5,694
57
belvidere,ill
Did you try the ground wire to the ecm like i said?We just had an issue with the ecm grounds getting burned out from the batt terminal touching the ecm and it burned the grounds out and all it would do was crank
1lowdiesel
<- wish i was there
Sep 18, 2008
1,615
In
Damn I'm about the check the codes on mine today too, hope I don't pull the same ones.
Have you tried a shot of ether?
BigDMax05
Peanut butter and ladies!
Feb 2, 2009
337
Indiana
Did you check all fuses? With the 4x4 buttons flashing it almost sounds like you touched the tcm with a ground source. But....... Hard to say. Not sure if lb7's will start with a fried tcm. I know lbz's won't.
TeaBagger2006
Im a Garrett Nut Swinger
May 11, 2008
3,123
15
Bis ND
When I fried my tcm it wouldn't do anything. All the lights would come on but no crank. I ran a ground of the tcm case to the body and she fired right up
5,841
hook your efi up and see what the cranking rail pressure is. you might try unplugging the FPR and see if it fires up too. they always run their best right before something happens ;).
