ya prolly easyest to do during pump replacment since you hafta move all that stuff anyhow
dont forget to cap the fprv
Line material: Parker Polyflex 2640D-03V32
Acording to Parkers site, this new line is rated to 30,000-40,000 PSI
YA, that outta hold:rofl: Looks to be about $70 per foot just for the line, no ends, adaptor fittings, etc.
The $70 a foot deal was a Hyd shop on line i found on google, just a chunk of hose. I would love to make my own and would surely save some peso's. Heres the issue with that, the Line kit from II also has 2 fittings, one goes where the Hi-Psi pop-off valve was on the distribution block and adapts to the rail type fitting crimped on the hose. The other, you remove a Torx plug at the bottom of the CP3 and insert a special adapter fitting (again adapts to rail type conn. on the line). Now the CP3 adaptor fitting has a "pin" on it that holds a ball/spring inside the bottom CP3 port. One might be able to get these fittings from Ind. Inj. ??? Also need to find the rail type crimp fittings for the line itself.
and that goes in place of the fprv?
thats another outlet from the cp3 im guuessin?
interesting.
and the line goes from the cp3 to where the fprv used to be on the junc block?
No, the FPRV is the solinoid thing on the CP3 buddie Now the line goes from the removed plug (pictured, bottom arrow) to the the junction block. now theres no spot on it so you remove the hi-psi pop-off valve---> it lets pressure off in the event it becomes to high, on the other end of the pop-off it tees into the return line system. Now what you do is the pop-off is unscrewed from the junction block and left hooked to the return line. it stays sealed cause its one way and the return is very low psi. now your left with an open port on the junction block where the pop-off was.....this is where an adaptor goes that the other end of the dual feed also goes!:hug:
No.. the FPRV ur talkin about is the FCA (fuel control actuator) also known as the FPR (Fuel pressure regulator)
the FPRV im talkin about is the fuel pressure relief valve that pops off when the RP gets too high thats located on the junction block
but anyhoo. That duel feed line its pretty nice, it gets rid of the fprv that could be leaking and robbing you RP plus it adds more fuel. i think my fprv is leakin is doing that to me right now i cant seem to make good RP. so im gonna plug mine.
