Question: Duel Fuel
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
Anybody install The Industrial Injection Dual Fuel Line? Replacing my CP3 This weekend and wondering if a worthy add on or not
mytmousemalibu
Cut your ride, sissy!
Apr 12, 2008
2,230
Kansas
Hey Fellas, Im Chris, AKA the guy with the dual feed line...
Ya it is a pricey piece but thats cause its a flexable line that is built to hold 30K+ rail psi! Ya, Im pretty happy with mine!:D I made a pretty good differance on mine especially with the big injectors. It made the truck so much more responsive! It also feeds the rails from a second ports so as not to let psi/volume drop off so easy. It picks up psi off of the CP3 from a second port on the bottom and feeds mine (LB7) to the junction block where the hi-psi pop-off valve is removed. I'd say II's claims of 50-70hp gains are prolly pretty accurite! I recently had to pull mine off temporarily and I like the truck alot more with it on, sure livens it up! So thumbs up from me!:hug::D
mytmousemalibu
Apr 12, 2008
2,230
Kansas
Sorry, Dale, i looked through all my truck pics and none even have a glimpse of it:eek:
its pretty well burried in there under all the harness and induction and such!
Heres pics of my new one they warrentied one, much heavier/beefy than the original type. II is great and took care of me no problem, orig one was too thin and burst, but this sucker is invincable:D
Only crappy part is its a sucker to install, like a sprung bull whip! and Buried in the valley, but worth it!:D
2500HeavyDuty
Book 'em, Danno!
Feb 14, 2008
2,209
Katy, Tx
www.myspace.com
what is the last 5 digits on the part number on the hose, ima find me one :D
mytmousemalibu
Apr 12, 2008
2,230
Kansas
Well the original hose Wasnt braided, it was a smaller grade of Parker polyflex, gray color and not as beefy. What happened is after a year or so i suddenly got a bad fuel leak, truck still ran. The hose had gotten a hole inside and burst. I still have the old one i forgot to send back so i might get pics for ya. II warrentied it without issue an sad they had a few that failed an since upgraded to the bigger stronger one i took pics of. Ill get ya guys the hose part number but problem is the rail fitting ends and special fittings on the CP3 and junction block.
