LB7: dual fuelers...again...
bullfrogjohnson
Big Girl!
Nov 20, 2006
4,167
Locust, NC
If you can TIG, or know someone who can, you can modify your stock neck to clear the belt. It's kind of a pain to use the short one with the belt running over the top of it.
Hell yeah, you have to watch your fingers if you have to pull the cap off of the motor is running.
13,765
834
I was going to try and mod the stocker but it seems like any way i try to fit it up it still hits the alt :confused: Unless i tilt it out away from the alt and weld it on a slight angle...then it looks like it will start getting close to the fan. Right now i cut the stocker short and put a fernco cap on it...had not other choice for the time being.
How are you trying to modify it? The lighting makes it pretty much impossible to see where it was cut and turned, but this should give you an idea about what I'm talking about.
attachment.php
