Dual feed line kit for dual cp3's.
IOWA LLY
Yes, its really me
Feb 23, 2007
2,275
How much is the line? Do they have a max pressure rating on it?
5,911
i still need to call back once i measure the OD on my compressor housing outlet to get the right oring flange ordered. ill ask then.
1,944
I know the old blue Parker lines were 33000psi max working pressure. I wonder if this is a new Parker design?
Ok, now I have a vision in my head of some goober using push-loc hose for that line. :rofl:
II has had that Cummins braided line for sale for a long time. Ive seen it mentioned on this site for years, but nobody had ever posted a picture of it on an engine. I just thought they might have come up with a Duramax one now.
juddski88
Freedom Diesel
Jul 1, 2008
4,657
120
Chesterfield, Mass.
I have the old thick blue flex line from them on my truck. They had to buy whole spool of it to sell the made up line at their price because my parker cost per foot was not much less than the completed line with fittings. The fittings are not cheap and the crimper needed to make it is not an average crimper. This smaller more flexible line is much nicer looking. But in 2011 the blue parker braided hose was the only thing we could find with that high of working pressure
CaptPhil
1,012
Delaware
I have the II line on the white truck. No issues so far at some very high rail pressure.
DPC
323
Adams, TN
Wow nice looking line, before this post if someone told me they used this for a high pressure line I would have thought they were crazy.
I had one of the original II blue lines and it failed after a few years, ended up making a hard line to replace it.
ikeG
Oughta Know Better
Apr 19, 2011
2,472
152
Western PA
www.facebook.com
The old school PPE kits used a long hard line to feed the back of passenger rail, so they still fed each rail seperately. Not sure when they switched it up but you cant buy them like that anymore.
SSchmi5519
LLY Cult Leader
Oct 19, 2008
3,387
Arizona
I just run the LBZ style hard line with the fuel block that houses the FPRV/Race-valve on my LLY. Both pumps feed the driver side rail. Much easier to install than the long LLY hard line too.
The hard lines are so large, I dont think you would see a problem feeding the one rail unless you were running some HUGE injectors and big pulse. Especially if you modified that little restrictor pill in the crossover line.
5,911
Ppe swapped to that setup in their kits now. You can't get the other single hard line from them anymore. I tried swaying Dan to find one lmao
5,911
Cool beans.
I'm assuming you don't need the fitting that come with it for the duramax application?
Yellowchevy
i have a ppe rail fitting im going to see if it works on, otherwise you would need the rail fitting to make it all drop in.
