Dual CP3 rail pressure question
13,716
779
After installing dual CP3s, I noticed on my truck that rail pressure was kind of jumpy at higher fuel quantities and RPMs. I thought it had something to do with my kit not being a mass produced kit, but today I was doing some logging on another truck that does have a mass produced kit that was doing the same thing. I originally had the stock B1015, and I modified it a little to try to fix it. Didn't really do much other than make it lose rail pressure a little. Is this normal?
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
Is this the LBZ?
Try adjusting fuel pressure parameters B1018 and B1019.
B1008 and B1009
Duty 99 and 1 respectively.
Otherwise, adjusting the large adjustment would be in order depending on response time in the log. Post a picture if you could.
13,716
779
what do you mean jumpy? spikes upwards or what
Spikes up and drops back down lower very rapidly. Here's a screen shot.
attachment.php
13,716
779
Is this the LBZ?
B1008 and B1009
Yes, it is on an LBZ, and thanks, I'll give that a try. What will that adjustment do? It's set at 95 and 5 now.
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
That sure looks like a rail pressure regulator chattering? But, try the large pressure compensation to be sure as well as large time compensation B1017 which you may want to slow down.
Edit: Being an LBZ, B1015 would be your best bet. Also, monitor you rail temperatures.
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
99 will help cut the fuel off, and give more control on volume for idle.
1 will open fully but, you may not need this if you have stock injectors and can hold rail. Usually not if a lift pump is feeding the cp3's.
13,716
779
I don't see a B1017 anywhere in my tune. What is "regulator chattering"?
What OS are you using Josh?
My OS is 3624, but the other truck I saw was acting very similar and is OS 6128. Here's a pic from one of the logs from it.
attachment.php
ecc_33
Junior Member
Aug 10, 2006
1,925
39
Amanda, Ohio
I have had the same problem on my truck for about 3 years now? Did you fix the problem, I still havent figured mine out. I have one stock cp3 and the other one has a modded SD fuel pressure regulator.
