Dsp5 switch/ efi live questions.
Duramax52513
Jun 23, 2013
99
I've been wanting to get EFI Live for my LB7 for awhile now but they are not the cheapest. I have come to conclusion that efi live is the best for duramax. But I'm confused as to what a dsp5 switch does. Does the switch just wire to your stock ecu and then you get the tunes? The reason I'm asking is I found the dsp5 on eBay for $40 and I'm wondering if I need anything else besides the switch to get the tunes?
rfletes79
649
165
Galt, Ca 95632
DSP, duramax switchable program. This switch wires into your ECM and works in conjunction with EFI live tuning. It does not have its own tunes, you will need to have your ECM tuned with EFI live and it would have to be written in DSP format for the switch to work correctly. The 5 represents how many programs are available.
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
If you buy from a vendor here they have the switches cheap, you will want a real tuner like the boys here so you can get ahold of them and they can tune you to perfection.
The switches alters voltage to ECM and intern alters your tune, that it in layman. Forget eBay and use the guys that make sites like his possible
