Looks like Kory is the first to offer it for purchase at this point. Pony up $4100 and it’s all yours.
Looks like he already offers soft tuning and switch already.
Because SOTF is nothing more than an electronic throttle stop that taps into a sensor circuit that he can use as a fuel limiter based on voltage. It is nothing at all like DSP5 from EFI Live where there are actually separate tables for all of the key things in the tuning to completely change how the truck runs at any and all throttle positions. Hell, if you know what the limiting table in the stock tune looks like for the sensor you at tapping into you can set up a switch with resistors to hit voltage set points and limit fuel to what you want, even on a stock tune.
Could not agree more!Because with these fuel temp limit styles, you might as well just run a single tune. :roflmao:
opcorn:
Yes. That's why I don't push switches on an LML. I actually don't push switches on anything. I prefer single tunes.
I’m the same way. Everyone wants a DSP5. Do people just drive WOT everywhere? Use your foot for how much power you want.
the ONLY time i could see a switch is a DSP2 for turbo brake or not for towing. Otherwise a single tune can do it all when you put the time in and to build it right. You definitely start to see why the maps GM built for a stock truck look the way they do :roflmao:
I actually like the dsp5 in the 05’. I dick around with the tuning and test it on the track. Easier just to switch the knob then flash the truck every pass. Big power guys can use diff tunes based on what the track will hold for power.
Everyday driving I’m in the big tune, to not piss the trans off to much.
No really. That's where throttle comes into play. It's not a light switch. Only thing Iike my dsp5 for is index classes.
Really, the throttle isn’t a light switch? Thanks for heads up.
My truck only runs 12’s so I wouldn’t know about having to much power. Are you really comparing your stripped down single cab to a ccsb street truck?
