Whats the general reason for doing this? And at what point is it typically necessary/truly advantageous to go this route? Certain HP threshold or et?
Just curious.
Just curious.
Just curious.
What kind of pricing and setups do ppl run? I think I need one. Mine seems like it can't put the oil back to the pan fast enough almost. End of pulls it will be really jumpy and fall down to like 20 psi
Not filled block or heads. Decided against Both. I don't have an oil temp gauge either. Gonna put a fleece logger on it this winter
yep keeps the crank out of the oil and if you have enough stages you can run a vacume, creating negative pressure in the crankcase makes more power beacuse there is less air for the pistons to push against
