Help: Driving in sand? Advice?
jnieberlein
Secret Squirrel Diesel
Aug 17, 2009
689
West By God
There is some sand driving in my future, any advice? I haven't driven in sand in years. Any air pressure recommendations?
TROJAN366
Gold Rush
Jan 13, 2012
2,474
MASS
I go out on the beach all the time. Lower PSI is always better. I drop down to 18-20ish but if its real soft sand or you are running a narrower tire you can go down as low as 12-15.
5,817
Drop that air pressure LOW. You want that tire to squish out so you float on top of the sand.
Momentum is also key. Without it, you can get stuck in a hurry.
5,817
Traction bars would not help, at all. They do not actually add grip to the tires lol
but they damn sure stop alot of that damn chatter/axle wrap you get back there when you go hitting the gas in 2wd with tires full of air :D.
02greysixer
1,829
North Central FL
That's what I was getting at ^^
I know the don't add traction but they make the trucks usable in some cases without 4wd since they aren't hopping and chattering like crazy. I can't speak for everyone but I know the 5 Duramax's I've been around will wheel hop to the point of self destruction in even semi packed sand. So I always go for the 4x4 in even the slightest bit of sand, where if I had traction bars I could just spin through short sections instead of going to 4x4. I live in fl, if it's not muddy is Sandy so I know sand, and I rarely have the chance to air my tries down for it :D
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
adeso
wait, what?
May 30, 2011
1,569
Minot, ND
Don't drive near spots that look like they have been recently been disturbed, or near large pieces of trash, look out for suspicious people or anyone watching the road holding a cellphone. Watch for wires coming up out of the ground. Should keep you safe playing out in the sand
5,817
where the hell do you play in the sand??? mexico?!?! :eek:
McRat
Diesel Hotrodder
Aug 2, 2006
11,249
Norco CA
www.mcratracing.com
Yup, keep moving, the faster the better. Avoid turning or braking. If you have a warning, drop pressures to 20PSI in both the truck and trailer, and kick into 4x4.
The issue with sand, is that if the tires sink, you are actually trying to go uphill. The faster you go, the less they sink. The bigger the footprint, the less they sink.
minisub
6-5/6-6;Whatever It Takes
Sep 11, 2006
474
Cleveland, OH
A decent jack, shovel, tow straps and a 12x12 board for the jack would be good to have in the bed....also a source of air for when you come off so you don't have to either wait in line or drive 20 mph to the nearest service stop.
5,817
Btw, ABS is your enemy in these trucks in the sand. I learned that the hard way long ago when climbing hills and what not. A quick in clip of one of the front sensors later and you can stop much better lol
3,727
296
Couldn't you just pull the fuse or unplug one for a less permanent solution?
Because on the road, ABS is helpful. At least on my truck, but I only have 33" tires, so I can lock them up pretty easy.
5,817
All you gotta do is plug it back in and it will go back to normal after driving over 15mph. I'm talking unplug the connector that's at the frame leading to a wheel speed sensor. Quick, easy and no lasting side affects unless you don't plug it back in
Ne-max
I like turtles
Nov 15, 2011
3,361
Lincoln, Ne
Well said. I had a couple pieces of plywood my first time in the sand and they saved my ass.
To the OP. Be careful where you stop, watch you temps super close, put panty hose over air filter, and remember your in a 7000+pd truck.
