Thanks, so a good step would be to pull the sensor, check for corrosion? I know you can't get a for sure conclusion that the bearing is bad or not by feel, but I check play each time I have the wheels off the ground for the front bearing units. I could hear the left one and never did get any play out of it, but you may have been able to see some done correctly with the proper tools.
