Drive psi gauge
chevyburnout1
Fixing it till it breaks
Aug 25, 2008
2,368
Berthoud, CO
I put my fitting in the passenger side exhaust manifold where my EGT probe used to be. Then drilled the driver's side to re-install the EGT probe.
Nov 4, 2012
182
Harrisonville Mo
Ok I was thinking the same but if you do it that way wouldn't you o my be watching g half the motor or am I thinking wrong and thanks for all your help man on both questions lol
yellowchevy
1,926
82
Louisburg, KS for now
I drilled and tapped the driverside manifold on my pickup. Only problem I have is the gauge bounces/flutters.
You can also put it into the up pipe like others have but you'll have to remove the up pipe for this.
Yellowchevy
chevyburnout1
Aug 25, 2008
2,368
Berthoud, CO
That air/water separator is a good idea. I should try that and see if it'll help keep the soot build up out of my blow off valve.
bluecollar
351
ia
I need to do this.. maybe passenger side works better cause their would be a couple other bends in the route and longer idk lol
jc1843
Sep 27, 2009
228
86
So Calf
If you have room, you could tap the exhaust from the other side, and "T" them together. That way it would equalize the pressure and reduce the bounce.
yellowchevy
1,926
82
From what I've read some say a small line (1/8") will stop the fluttering and others say a 1/4" worked for them.
I've got 3/16" or 1/4"(can't remember at the moment) and mine fluttered really bad when I first installed it. I took a pair of pliers to collapse the line and that helped calm the gauge down but not enough so I'm going to try the 1/8" line I bought. I also think I've got to much copper line so I was going to first remove some and try that; then install the 1/8" line.
I could be wrong though, it's known to happen.
Yellowchevy
