drive pressure
c_murray7313
Addicted to HORSEPOWER!!!
Apr 2, 2007
145
41
Ocean City, Maryland
thanks guys, im prolly gonna do like simon said and get a 30psi fuel pressure gauge and use it for the fuel pressure and take the 100psi aguge and use it for drive pressure. id do the switch thing but i need to fill another gauge spot anyway. thanks guys.
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
Exposing ignorance again... I 'm not a turbo diesel guy, yet.
What is drive pressure and why monitor it? What will it tell you is happening?
Thanks.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
well its basically the back pressure of the exhaust, and on the VVT its a key component to running a good tune IMO, also with larger turbos and twin set ups
ideal would be a 1 to 1 ratio( depending on turbo) or some where around there and vane posistion for us stockers plays a huge role, aftermarket turbos need timing and fuel adjustments to alter there drive pressure
when i installed the HTT mine would follow boost, when i had the stock on it would be double the boost and sometimes tripple:eek: Vane altering would make dramatic changes to this;)
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
ok, this is what I used
20" SS tubing
4'- 1/4" in hose something that can stand some heat atleast a couple hundred F
a connection to hook from the Exhaust manifold to the tubing
a connection to hook the hose to the tubing
a connection to hook the hose to the autometer sensor
a 0-100 psi electric boost or fuel press gauge
and ofcouse whatever you need to install a gauge ( wire, fuse )
hope this helps!:)
Thanks to Dale and his amazing picture taking.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
20" SS tubing
hope this helps!:)
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
probably the best thing you guys could use is a hydraulic hose from John Deer
or even better a steam hose
i used the braided simply because ....it's so readilly availible for me
just basically find something good for heat and 100psi-200psi
home depeot may have some copper tubing for hot water tanks and plumbing
might be a good place to get the tubing
FWIW the lenght that i used it not carved in stone you could use longer or shorter,
The line wont get that hot as your EGTS, unless it is actually flowing through the line
but i would try to keep the tubing to atleast a foot or more.
here is a link to autometer gauges any of the 0-100psi fuel will work
http://www.autometer.com/cat_gaugesearch.aspx
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
Bringing this back for more discussion :D
Simon, my new gauge should be in in a few days, you ready to make the tutorial ;)
9,905
151
We need a "How to log drive pressure with EFI" tutorial too!!
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Maybe if everybody would PM Simon, he just might do it ;)
i would love to tie into the EGR 0-5volt
also,something i didnt realize is with the cold weather my SS tubing is freezing:confused: im geussing a little condesation and it sits in a low spot then overnight it freezes......who would of thought?
you got all the pieces you will need yet larry?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
hose
tubing
electric gauge
basically once you find some tubing to use, find out what connection it is? is it NPT fitting or what? then you need to install this into the manifold and that will be a 1/8" npt so make sure you can install the tubing onto the 1/8" npt fitting coming out of the manifold
then on the other end of the tubing you will attach your hose, Again you will need to adapt to the hose from the tubing
then you will need to adapt to the hose to the sensor that will come with your gauge ( probably 1/8"npt or 1/4")
as for the hose try and find some good higher heat hose atleast good for 100f
i can grab a hold of my hose after the truck has been running and it dont burn me so it doesnt have to be that high of temp
but if you can, find a hose that is crimped fittings not hose clamped together.....if you can?
install the gauge and run the wires and sensor through the firewall and connect it to the hose
LarryJewell
Jan 21, 2007
10,152
58
San Angelo
hose
tubing
electric gauge
OK, I printed the pics from post # 18, i'll carry those to the parts store :D
LarryJewell
Jan 21, 2007
10,152
58
San Angelo
I thought in a different post you said not to use copper tubing :confused:, so is copper tubing ok instead of stainless "I'm assuming that is what you were refering to when saying SS"
Using copper tubing might make this a one stop shopping trip ;)
Where did you get the braided hose from?
