Tip in pressures as the turbo tries to build boost is a big deal besides the obvious max output numbers.
On VVTs, it is worth taking out some max vane angle on tip in if they are exceeding 3 times demanded boost or if they exceed about 90 PSI at any time.
On waste gated turbos, a sharp increase in drive pressure usually indicates you have hit the wall for what the turbo can produce.
VVTs will usually run 1.75:1 to 1.25:1 steady state with high tip in pressures till they hit the wall.
I have never personally seen a 1:1 regular turbo. In their operating range, I've usually seen 1.25:1 on a good performer.
