100psi fuel or boost? and why? Mechanical or electric? why?
Also thoughts on a 100psi mech oil pressure gauge? as I have one handy...
kthxbye
kthxbye
kthxbye
Gauge doesnt know if its oil or air or boost
use electric and you can log alot of them with EFI and ofcouse what JB said
Use a short piece of tubing then run braided hose to the sensor is what i like to do.....Do a seach there is tons of threads on it
I ran ss tubing straight up from the manifold it is only about 8" long I don't like the idea of a coil for a few reasons
it freezes in the winter
it collects soot and would be a pia to clean
it's not needed , many people have the misconception that the temp is the same as the egt this is not true unless it's flowing thru the tubing. The 6-8 pipe is just needed due to the ambient temp coming off the manifold.
I've been running a drive press gauge for about 3-4 years and never melted any lines , it is probably the best thing you can do to a truck with a vvt it's a real eye opener and will help you optimize your turbo and tuning
that's not ghetto I use a spare boost sensor and fuel temp sensor for all sorts of thingsCall me ghetto but I went to a stealer and got a couple of factory ends and made an extension for the factory oil pressure sensor wire and used a second oil pressure sensor so I could log it as oil pressure with efi and not have to run any new wires. When I get drive pressure where I want or didn't need it I unplug the extension and plug the factory sensor back in. It's a pain to get to the plug if you use it much but I didn't plan on leaving it for good and I had the extra sensor already sooo... You just have to put up with the oil light and check gauges light when you're idling or putting around.
