Been a bit busy. Casper is now running again but with a special S400 charger on top from Borg Warner/AirWerks/HighTech.
I need to start recording drive pressure, so I drilled and tapped the pedestal spacer for both 1/4 NPT and 1/8 NPT.
I bought a Oil pressure gauge from Summit for about $20. I found that when using a 470 ohm resistor to split the voltage:
120 PSI = 1.33v
100 PSI = 1.71v
80 PSI = 2.15v
60 PSI = 2.70v
40 PSI = 3.15v
20 PSI = 3.60v
0 PSI = 4.20v
While not perfect, this should give a good enough range for EFILive's external ports on the V2, which understands 0 to 5.0 volts.
I did the mapping with an air compressor and eight AA batteries, so this should give me some extra wiggle area when dealing with a car battery and alternator.
Next I got:
1/4" aluminum tubing (to dissipate heat), 3' long
AN-4 to 1/8 NPT fitting (male to male to go into the pedestal)
AN-4 to 1/8 NPT fitting (male to female to the gauge)
AN-4 nuts and sleeves (2 each)
37 deg flare tool.
Materials are about $30 plus tools.
I should hook it up tomorrow and take pictures and draw a schematic. Not much of a schmatic since it's one stinking resistor.
120 PSI = 1.33v
100 PSI = 1.71v
80 PSI = 2.15v
60 PSI = 2.70v
40 PSI = 3.15v
20 PSI = 3.60v
0 PSI = 4.20v
Next I got:
37 deg flare tool.
