Drain coolant
downtownford
Jul 20, 2015
3
How do I get to the radiator drain plug. I want to drain my coolant on a 2006 lly duramax
andy-stevenson
Jul 7, 2013
838
Not sure if your truck would have the drain or not. If it does it would be on the bottom passenger side corner. If not you just have to pull the lower hose on the bottom passenger side.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Don't think 06 and newer have them :(
minerigger
2,660
Casper, WY
Nope get ready for a bath...I fuggin hate that they dont. I have yet to figure out a half decent way of doing it so I can save and reuse it
1,840
Keep the overflow cap on.
Try to find a wide tube (PVC?) to put the end of the hose into right from when you pull it loose to help guide the fluid into the pail. I used one of the I/C pipes.
rg3whitelbz
Jan 19, 2013
166
Maryland
I like my big black concrete trough to cover the largest area and probably holds 7-8 gallons.
Sent from my 0PJA2 using Tapatalk
c20elephant
C20ELEPHANT
Apr 25, 2013
2,065
Phoenix, Arizona
Next coolant drain this is going in, Home Depot has some mortar mixing tubs 6" in height and 20"x28"..
Awenta
4,090
CT
Anyone try tapping a hole for a drain? A 1/4 npt air compressor drain would work?
Guess you don't need to do it often enough to make it worth while though.
dieselfelon
May 6, 2016
MN
Nice... I was thinking of having one made but I found one online. It is made specifically for the Duramax. I ordered one and have received it. I haven't had a chance to install it yet. When I do, I'll report back.
Here is a link.
http://mfrindustries.com/
It looks pretty nice. It is made of stainless steel. The drain plug looks like a common GM engine oil drain plug available at napa if it strips out.
Mark
N2BRK
2,049
363
What about adding a tee into the small house running under the main? You could cap it when not draining.
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
X3. Just used one when I did the water pump. Catches 95% ....Just not the stuff that sneaks down the block/lines/skidplates/etc
Wyley87
Jul 21, 2012
75
Texas
I got the one from Mfr. Used it during a coolant flush. The constant removing of the plug caused it to start leaking. I i installed a fumuto valve where the plug used to be. I might ad them to the sides of the block too but I haven't decided just yet.
Easy peasy draining now.
Sent from my SAMSUNG-SM-G930A using Tapatalk
