I notice the Et streets are really soft, when your guys trucks are setting all week, would you take them off? Does it hurt to let the truck set on them?
not to derail the thread, but i've been curious....what do a set of drags gain you over a...say proxies? traction, lighter weight? but really that much diff, in a 4wd?
Whats the best brand and size to run?
The only 2 brands i would recomend is either M&H or Micky Tompson . I have the MT ET streets and so far they are very impressive , the other thing better would be a full slick .
As far as size the taller the better ( to a point ) but the only way you would be limmited against the popular 28" sizes is if you plan on running more than 120 MPH or so in the 1/4.
My MT's are around 30" tall ( 305/45R18) they should be fine up to 130 mph or so in the 1/4 . Maxxed out has ran over 130 with them though .
What was the difference in your 1/8th mile splits from street tires to the ETs?
With a 4wd truck running drag radials, how do you actually get them hot and sticky? Not like you can do a 4wd burnout. Do you guys just roast them in 2wd and then lock it in 4wd? So a 28" is good up to 120mph? Thats moving!!
Also is your truck lowered all the way still with the 30" radials?
You dont get them hot and sticky, just go around the bleach box
i used to be a firm beleiver in this but have since started to heat the rear tires up and it lets me leave hotter and has thus drop 0-60 times...
