Drag Radial?
NJ_LLY
Back in action
Nov 4, 2008
560
Browns Mills, NJ
Im looking into a set of drag radials for my truck but dont know which are better the M&H or Mickey Thompson. The other thing is that summit has two different part #'s for the M&H ROD08 and ROD18. Does anyone know the difference? I called summit but they didnt know
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
plenty of people have been happy with the m&h's , i am going to try out my MT's tomarrow . not shure on the difference on part #'s i would call m&h . i know my friend dimitri has cutt 1.6's on a very slippery track with the m&h's . we will see what my how my MT's compare . tuff to compare unless you ran each on same truck same day .
548
im looking at smoothing the rear calibers and running 15"s and have DOT slick 33X14-17" size options
both hoosier, goodyear, MT and M&H.
along this line http://www.mandhtires.com/store.php?crn=73&rn=321&action=show_detail
not sure if it is worth buy a 30" tire due to my wheel base being soooo loooonnng
along with a 60/40 weight split over ~170" wheel base doesnt help transfer at all :baby:
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
just bought a set of these for the race truck. Been using Nathan Nitto drag radials, These are a bit wider.
MT 3786R P305/45R18 29X11.50R18
What wheels are those your run them on? Any reason for using 18's? Wouldnt 16s be lighter?
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
the 305/45r18's are the tallest tire they offer in bigger than a 15" wheel . they are 29" tall .
Oh, that makes since then, so if these are gonna be ran, a light weight 18" wheel needs to be found.
What about M&H, do they make comparable sizes in 16"?
TrentNell
Jul 7, 2008
7,543
slc tuah
16" m&h you can get up to a 28" , move up to 17" and you can get 30" but they are pretty wide . my 18" wheels are 26 lbs if i remember right , the wheel and tire combo is about 58 lbs . my wheels were 135 bucks each from discount tire direct .
Rhall
Old Skooler
Aug 12, 2006
2,241
41
Texas Y'all
16" m&h you can get up to a 28" , move up to 17" and you can get 30" but they are pretty wide . my 18" wheels are 24 lbs if i remember right , the wheel and tire combo is about 58 lbs . my wheels were 135 bucks each from discount tire direct .
What brand are they?
TrentNell
Jul 7, 2008
7,543
slc tuah
did you run this weekend trent?
he made one pass and blew though the brakes then got rained out :(
yep kat is right made one pass and building boost the truck went through the brakes , hydoboost has been getting a little week and it pulls a little harder with the shorter tires , not a good excuse but i didnt get another run to try , i did get a launch just the slip was off from the clock starting when i red lighted , didnt slip a tire and mph was down a hair like it should be when you get a good 60( dont know why that is ? ) but i have to wait a few weeks for track to be open again :(
