Now you're adding new terms. Lol what is the V2? Dsp switch?
A dsp switch is a dash mounted or mount anywhere you want switch. This switch you change when you want to switch tune levels that's flashed in your Ecm from the tuner.
Info on v2 and autocal.
http://www.efilive.com/flashscan-v2
http://www.efilive.com/product-info-autocal
http://www.efilive.com/product-info-efilive-tuning-tool
A FlashScan Device is Required
To be able to create tunes for your customers’ AutoCal devices, you must:
Connect the AutoCal device and your FlashScan V2 device to the same PC and select the link option, or
Send a file that was "saved for AutoCal" to your customer that the customer flashes into their vehicle. AutoCal will link itself to the FlashScan device that was used to save the file for use with an AutoCal device.
Differences between FlashScan V2 and AutoCal
There are significant differences between FlashScan V2 and AutoCal for end users. It is important that both the tuner and the tuner’s customer (end user) understand these differences.
With FlashScan V2, end users have the ability to create, view, and modify tunes. With AutoCal, only the tuner has that ability.
Tunes from multiple sources can be flashed with FlashScan V2, however AutoCal is limited to flashing tunes provided by a single tuner.
